Celle-ci n'est pas une
http://www.safaricondo.com/alto/1713/index.php
impressionnant, non
Pat.
Et si la solution pour Cernay (lâché par Hymer ) se trouvait justement là ...Boulhaya a écrit :Ce qui me plait dans cette caravane, que nous ne verrons jamais par chez nous,
Oui déjàA suivre, à voir et surtout connaitre son prix !!!???
La solution est pourtant simple (quand on la connaîtMerci pour les images, j'avais tenté mais![]()
d'autres infos http://www.aa1car.com/library/trailer_brakes.htmA Controller Is Needed
For the brakes to work, trailers must be connected to a tow vehicle equipped with an electric brake controller. Unlike surge brakes on a trailer, electric brakes are not independent of the tow vehicle. When you step on the brake pedal in the tow vehicle, the controller receives a signal from the brake light switch that the brake has been applied. This causes the controller to switch higher current power to the trailer brake. The degree to which the trailer brake is applied is determined by the adjustments the driver makes to the controller.
The Mechanics
When the controller sends current to the electric brake, the magnet is energized, causing the magnet to be attracted to the inside of the brake drum. This attraction makes the magnet try to turn with the brake drum. Because the magnet is attached to the actuator arm, the rotation of the brake drum forces the brake shoes out against the friction area of the brake drum, thus slowing the trailer.
Safety Features
Trailers equipped with electric brakes are also set up with a breakaway switch. This switch automatically applies full power to the brakes in the event the trailer becomes detached from the tow vehicle during driving. The 12 volts required to do this comes from a small battery mounted on the trailer solely for this emergency protection.
traduction google :
Un contrôleur est nécessaire
Pour que les freins fonctionnent, les remorques doivent être connectés à un véhicule de remorquage
équipé d'un contrôleur de frein électrique. Contrairement aux freins de poussée sur un
remorque, freins électriques ne sont pas indépendants du véhicule remorqué. Quand
vous appuyez sur la pédale de frein dans le véhicule de remorquage, le contrôleur reçoit
un signal de l'interrupteur de lumière de frein que le frein a été appliqué.
Cela provoque le contrôleur qu'il passe plus de puissance en cours à la
freins de remorque. La mesure dans laquelle le frein de remorque est appliquée est
déterminée par les réglages du pilote permet au contrôleur.
The Mechanics
Lorsque le contrôleur envoie en cours pour le frein électrique, l'aimant est
sous tension, provoquant l'aimant d'être attirés vers l'intérieur de la
tambour de frein. Cette attraction fait l'aimant essayer de tourner avec le frein
tambour. Parce que l'aimant est attaché au bras actionneur, la rotation
du tambour de frein forces les semelles de frein contre la zone de frottement
du tambour de frein, ralentissant ainsi la remorque.
Caractéristiques de sécurité
Les remorques équipées de freins électriques sont également mis en place avec une échappée
basculer. Ce commutateur applique automatiquement la pleine puissance sur les freins à
Si la remorque se détache du véhicule remorqueur pendant
de conduire. Les 12 volts requis pour ce faire, vient d'une petite batterie
monté sur la remorque uniquement à cette protection d'urgence.
Utilisateurs parcourant ce forum : Aucun utilisateur enregistré et 12 invités
